DodgeFan79
Member
I have a 92 Dodge Dakota extended cab with a 5.2. It has the OD tranny and is rwd. Has 3.55 gears but those are going to be getting swapped out to 4.10s. Also has a limited slip.
My questions are has anybody used these cams on Ebay? | eBay
as you can see he has a huge selection for the Magnum motors. I plan on dropping a bone stock 5.9 in the truck with upgraded valve springs and a air gap intake clone manifold. Will be running a carb. What camshaft from this company would be best for my application??? I will also upgrade the torque converter to a 2800rpm stall when I swap the motor out.
Would this truck run good with the 5.2 and a cam swap? It runs good but I want more power so I was thinking 5.9 swap but may consider just keeping the 5.2. Definitely going to go to 4.10 gears and run a carb.
Any help would be greatly appreciated. Just wanna make sure I pick the right cam. Thanks
