help with over heating
long time gone
Yep, major heat by retarted timing at cruise. Easy fix, use vacuum advance, might be your only solution. You are missing out on 15 to 20 degrees of advance when you need it. It all goes away at WOT.
The nice thing about vacuum advance, done right, no impact on power.
even an increase to 34 or 35 total may help,if you can.
i think it was superbirds that were recalled due to the fan not moving
enough air...they were overheating on the highway.
..your shroud and 2500m cfm electric fan may be restrictive at highway speeds.
I think I will buy a new shroud and twinn fan combo from challengergary
to my idea and test there in not enough goint true the rad at highway speed
the shroud that I bilt doesnt do is job on highway but do great in slow traffic
and I dont really do slow traffic except here in town never much more than 10 minutes so it could held to 195* in town before I installed the fabricated shroud
so i will buy this shroud and fan set up the minute a get the cash
http://www.ebay.ca/itm/3-Row-MOPAR-...Parts_Accessories&hash=item2ebefc8802&vxp=mtr
