Help with pistons and rods
yes but the compression is the issue the mag head has a small combustion chamber you need to calculate true compression
I understand , just tying to get to a rough idea, are these like 14:1 or like 9:1? It's a street motor and want to run on pump gas, just making sure they will.
with dish pistons and eddy close chamber heads...probably around 9.5 to 1....but that is a guess without knowing deck height and head gasket.
