Help with those thread cutting nuts on emblems.
gdizzle
los angeles
So on the 66 dart sedan, which just got painted. Some of the letter emblems had been glued on, due to stud being gone.
I bought new (used) emblem letters and the studs are well worn. I bought a supply of thread cutting nuts, like the ones that are OEM. For the 1/8in stud, but due to some of the studs being already worn and cut, I cant get any bite with the new nuts. I tried wrapping the stud in electrical tape, and no good. Does anyone have a fix to get these new nuts to go onto the old worn studs???
Nut big side down on a flat surface like a concrete floor, anvil, etc.
With something that has a flat end, give the high points a gentle push down, it does not take a lot.
This closes up the hole diameter some.
Repeat / adjust as needed.
Go to Ace Hardware and get yourself some smaller nuts.
Sometimes a washer or 2 under the nut will move the nut up the stud where it has some bite. I'll also tap on the nut on a flat surface as already mentioned.
I just did my console trim. I threaded with a machine screw die and used machine screw nuts.
Thanks for all the ideas. I did try hitting it with a hammer, but still did not bite. Some of these studs are super mangled and thin.
If worse comes to worse you can simply use some 2 part epoxy unless you plan to remove again in the near future. Most people don't know that you can easily get epoxy to release with a little heat. I good heat gun will make it meld if you ever have to remove the nuts.
THE MORE CHEWED UP THE STUD IS THE BETTER THE EPOXY WILL ADHERE!!
Treblig
