Captainkirk
Old School Mopar Warrior
That decision has been made already!Given what you have - I'm no fan of having to mix fuels on a car that runs on the street. I build primarilly street engines that run on pump gas. Yours would be no exception. So this is what I'd do and why:
- Use the forged crank - you will internally balance it and it's got the heaviest counterweights making it the best candidate.
Not contradicting myself here, but if I were to go with flat tops, wouldn't I be better just saving up the Almighty Dollars for a set of, say, Keith Black Flat-tops? Not sure how this would affect my CR with the 67cc bowls, though...- Take the pistons and either mill off the domes if possible - as was mentioned - just flip one over and look. A flat top with an open chamber head is where I'd want it.]
- Static ratio no higher than 10:1. Prefer 9.8:1 if it's doable.
If I decided to go with the flat-top KBs, and was gonna run 2.02's....why wouldn't I want to just use the X-heads I have that are already 2.02'd? JUst asking. Yeah, I know the J's are ported, but I could probably get the X's ported for what I would spend having 2.02's installed in the J's, not to mention my CR would be higher....- Use the ported Js. The oldschool Tony can keep the 1.88s. They will need to be sunk to be run - use at least 2.02s and if the seats are bad I'll go as large as 2.05s assuming the porting is good and they can use it. If you think the 2.02s are too large take a look at any modern 4 cylinder that has 2 times the valve area and 1/4 of the displacement. I'll bet you the cost of the engine that you can't feel any loss of torque directly related to a larger intake valve.
Is there test data to back this up, or is this from personal experience? Everyone has a favorite, and there's so much out there it's hard to choose.....- Buy an Edelbrock RPM Air Gap. I'll bet that same dollar amount that you will feel a loss of low end by not using this intake - and it will still make the same or more power up top.
The reason I chose the 650DP in the first place was using the flow formula in the Holley Carbs & Manifolds book which indicated a 750 would be too much flow, especially with manual secondaries. Has that opinion changed over the years? Seems a lot of things have.......- lose the smaller Holley . Buy something that gets you up around 750 in the oldschool cfm ratings, or 670 in the modern wet-flowed stuff (like the Street Avenger or HP series Holleys).
Not the Mopar Performance module? If not, why not?- Keep the factory distributor but recurve it for your package. Get a Standard Ignition control module for it.
Yeah, will probably go with budget headers....- Buy a cheapie set of headers at minimum or a nicer set if the $$ is there. Either will work, the more expensive stuff makes a little more power (not much) but is easier to get in and will not be damaged by road dips or speed bumps.
If, and I say IF....I decided to go with the X heads, it wouldn't matter about the porting because I could have them ported and flowed at the time of rebuilding. But yeah, I see your point. Especially if I decide to run the J's.- You said the heads were ported - have them flow tested and post the results before I can recommend camshaft. Also tell us what they have/had for rocker gear.
Thanks for all your input!!!!:hello2:
