Quicktree
73 Duster Morrison square tube chassis will cert to 7.50
ladder bar coil over in the rear with a strange 9" rear housing and axles.
Strut front end.
Wilwood 4 wheel disc brakes, floor mount master cylinder.
Custom motor plate.
new quarters on the car.
Triangle Aluminum fuel cell
Flaming river rack and pinion with steering linkage and grant wheel.
Weld wheels all around.
fiberglass doors with mounts.
1 piece glass 70-71 front clip.
tin work about 70% complete.
Turbo Action Pro Glide with new J&W Ultra bell kit and trans shield.
500ci 1999 Mega block Hemi form the MC foundry
Crower billet stroker blower crank.
Oliver rods with JE pistons rings and locks.
Milodon dual line oil system with swinging pick up.
Jesel belt drive.
Meziere water pump.
Barton dominator intake if you don't want to run a blower.
Chrome valve covers with tubes.
Mopar Aluminum heads CNC ported by Modern cylinder, set up with large roller springs.
MSD billet dist.
KB rocker shaft assy, only thing missing is the rockers.
ATI Damper.
timing chain and gears.
I am sure I left some things out. serious inquires only
I may sell the car separate or consider trades.
27K for everything, PM me
http://s579.photobucket.com/albums/ss238/Quicktree09/73 duster/
Strut front end.
Custom motor plate.
Jesel belt drive.
Meziere water pump.
MSD billet dist.
ATI Damper.
