Look at post #125. That picture loaded as others which I removed. I don't know why I can't get his to load.oh sure, blame technical difficulties...
*rolls eyes*
*rolls eyes*
muh-huh.Look at post #125. That picture loaded as others which I removed. I don't know why I can't get his to load.
Is it possible that he has some kind of a lock on his pictures? I was able to load several others which I removed but none of his will.muh-huh.
sure thing chachi.
sorry dan, i'm in M&O so i don't have the slightest idea. you might want to put in a request with IT see if they can help ya out.Is it possible that he has some kind of a lock on his pictures? I was able to load several others which I removed but none of his will.
I'm sure that they didGM 4.3 V6
Bush Series Racing
Nemechek and Earnhardt
Nemechek for the win. Those 4.3 V6 engines sounded like Bumblebees going around the track.
Thanks for sharing this information with me, I'll let him knowFor the carburetor itself, the Edelbrock 1409 model is a popular choice, which is a 600 cfm, 4-barrel carburetor with an electric choke and single inlet.
This carburetor requires a specific calibration kit, the Edelbrock 1485, to properly tune it for the 4.3L V6 application.
The calibration kit includes metering rods, jets, and step-up springs tailored for the engine's requirements.
____________
Imagine that, a specific calibration kit, the Edelbrock 1485, to properly tune it for the 4.3L V6 application !!!
This is probably what is wrong with Randy's 4.3 V6 hesitation problem.
Needs a specific calibration kit for the 4.3 V6 engine.
So Yeah, wrong carburetor.
____________
I told Randy about the calibration kit and he said that don't make a specific kit for any engine so I said what ever.For the carburetor itself, the Edelbrock 1409 model is a popular choice, which is a 600 cfm, 4-barrel carburetor with an electric choke and single inlet.
____________
Interesting that the met rod springs are different.
Randy said that's not sowhy so?
I'd be willing to bet that he doesn't have it running right before the end of the year. I told him that he wouldn't have it running by the end of the summer. He doesn't believe that there's specific calibration kits for a carburetor for a particular engine.oh, so now "randy" works for edelbrock? knows the calibration settings between marine and auto carbs?
puh-leeze
"randy" can't figure out how to make a crap *** crap V6 run right, i doubt he even knows which end of the wrench to hold, let alone the intricacies of specialized carburetors.
why would you use a marine carb in an automotive application?If it were mine... go with the Edelbrock 1409 600 cfm carb with the 1489 Calibration Kit, and of course the stock HEI distributor with and External E-Core coil. Fast burn ignition, timing set to 8 degrees BTDC (because the hot fast spark acutally advances the timing > so back it down 4 degrees to put the fireball in the right spot.)
sure, lemme just get my ouija board...Run they will, just ask Dale Earhardt
ain't that the truth, especially with an attitude like that.What Randy doesn't know, he will never know...
what does it matter. you already said he bought another car.I'd be willing to bet that he doesn't have it running right before the end of the year. I told him that he wouldn't have it running by the end of the summer.
jfc. do you even read? and if you do, are those words and phrases understood?He doesn't believe that there's specific calibration kits for a carburetor for a particular engine.
He wants to sell the vega and I don't want that pos.what does it matter. you already said he bought another car.
there's a specific calibration kit for that carburetor for that engine in a specific application.
if you can't be bothered to go on edelbrock's site and read it there, i included a screen grab and highlighted the information upthread.
why not? you're and ace with the wrench and you'd have that thing humming in no time!He wants to sell the vega and I don't want that pos.
I've tried everything I know to post them and they won't, I don't have a clue why they won'tLet's see the Pictures of the Vega and the V6 engine in it that you promised... just don't sluff it off.
No excuses, post them up.
