"Hey, That's A Trick Question"
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
Mopar Trick Questions
A} How many 1968 Plymouth Road Runners came thru with a 440 Engine ?
B} How many years did the 1966 Dodge D/Dart run in D/Stock ?
C} How many Hood Scoops were placed on the 1966 Plymouth GTX ?
D}Was the 1970 Dodge Dart GTS available with a 383 Engine ?
E} How could I get a 440 Engine in a 1972 Plymouth Road Runner ?
F} What NHRA Class did Dick Landy run in with his 1967 Plymouth Satellite ?
G} Was the 273 Commando Engine available in a Dodge Dart ?
H} Which Mopar Engine came though with a 'Tri-Power' ?
I} The 340 T/A Cylinder Head could be found on what Plymouth Engine ?
J} Solid Camshafts were found in what Mopar Engines in 1967 ?
K} Which Mopar came thru with a Posi-Rear ?
Answer to a is a trick! There were no roadrunners with a 440 except the A12 cars
Oh I didn't fully read the question the answer to a is none
K: none
I: none, T/A was a Dodge.
J: All of them. none were hollow.
H: none
G: none, Commando was Plymouth
E: bolt it in.
C: none: GTX started in 67
B: many. Arent they still running?
K: none
H: none
E: bolt it in.
Very Good,
You went in a different direction on a few, but.....I like the way you think....
