David Musselwhite
Guys and gals I have a new set of speedpro h116cp .030 pistons. These are the high compression slugs with a 1.660 compression height. These are hypereutectic pistons with the skirt coated for super high speed zoomming down the drag strip. With stock uncut heads about 73 to 75 cc they will give you a solid 9:2 to 9:5 compression. You running 318 heads you said well you looking at about 10:1 blow the doors off. $300 shipped to your door in the lower 48.
