[SOLD] High Performance 318 pistons
David Musselwhite
Winston-Salem NC
Guys and gals, I have a set of 8 brand new SPEED PRO HYPEREUTECTIC .030 over pistons. These pistons stand a little taller in your 318 cylinder bores with it's 1.755 compression height.Help increase compression, more stable piston at high rpms with its hypereutectic aluminum alloy and they do have the coated skirts. Flat tops no valve relief, comes with pens. $200 shipped in the lower 48. I do PayPal or money order when it clears. They are great pistons for the teeners
Uh because these pistons has a taller compression Height than stock pistons. Especially if you have a 80's truck special option low compression teener with a compression height of 1.660.
