Hole in water pump 383
Heating / Cooling / AC
  1. dustya_383
    dustya_383 Well-Known Member
    1,148
    40
    Oct 7, 2009
    san Jose Ca
    Local Time:
    12:45 PM
    I have coolant leaking from the hole on the waterpump (big block) why is it leaking now and wasn't leaking before I did a radiator pressure test and that's where my leak is how do I fix it ??!? ThAnks
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    20,861
    7776
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    2:45 PM
    ................U need a new w/p,.................kim.........
  3. Dartnut
    Dartnut Don't hate me because i'm beautiful
    11,889
    5046
    Apr 19, 2007
    Southern Alberta
    Local Time:
    1:45 PM
    Yep, your water pump is shot.
    Easy fix and cheap too.
  4. 67Dart440GT
    67Dart440GT Seriously Long Member FABO Gold Member
    3,610
    1391
    Mar 15, 2010
    53545
    Local Time:
    2:45 PM
    Probably coming from the weep hole. Tells you the pump is bad or the seal inside. Probably the pressure test made the seal fail.
  5. dustya_383
    1,148
    40
    Oct 7, 2009
    san Jose Ca
    Local Time:
    12:45 PM
    Was already leaking from there. Was doing pressure test to find exact location
    Thanks tho I'll be replacing pump
