Holley 1920 linkage needed
dartman59
Florence, Massachusetts
Maybe I should be in the parts forum, but this is such a rinky-dink part that I figured I'd start here. This weekend, while clowning around, I broke my accelerator pump linkage rod! It's about 1-1/4" long, has a U-bend at one end and an L-bend with cotter pin at the other end. I was bending it, trying to get a longer shot out of the pump, and I broke it! :banghead: Should have left well enough alone. If anyone has one I'd gladly pay reasonable money for it. I sold a bunch of old 1920 parts on eBay about a year ago--I knew that was a mistake!!
If you can't find one closer, I would have one. You change the pump output volume by putting the rod in a different hole on the main shaft bracket.
