[WANTED] Holley 1945 Rebuildable
Mako21
Miami
Looking for a good condition, Rebuildable complete Holley 1945 carburetor. Going on my stock 1976 Dart slat six. Thanks.
I have one off an 82 D150. I didn't run this but I loaned to another member for a few weeks and it worked fine for him. $40 plus the ride if you're interested.
I will take it, there isn't any lean burn attached to it right?
I think by 1981 was lean burn years.
Correct, this was the lean burn years. When I got the truck all that junk had been removed, so that's the best answer I can give you. Let me go dig it out of wherever I stashed it and I will shoot you a PM with shipping and info.
I think it's best if I post up the actual casting number I need to keep things correct on the Holley 1945 model I specifically need. I'm concerned on the lean burn models it is always pulling full vacuum from its port, hence advancing my ignition full time, as opposed to ported vacuum port which mine currently has.
