holley 2 bbl carb numbers.
66Dvert
Working on my custom car parts again!
Webster , florida
It just might be a marine carb, but the float bowl is the ford/car style. someone might have changed it out i guess.
I'll just have to take it apart and see if it needs rebuilt. I'm stockpiling parts for the / turbo setup for my dart. it's just weird I can't find any site that lists those numbers. I even sanded it down a little to make sure I read the numbers right.
I Binged Holley 75006 and it took me to that site, top of the list. Although I don't see any of those numbers on the site.
Its a marine carb the J air vent and throttle shaft are marine , the ford inboard 302 used them . You will need to search in the marine holley books ,but looks like a 2300C type model , good luck
Found it !!! OMC 1998 V6 - 4.3 used the 75006 holley 2 bbl
a mercruiser? v6 ,cool any spec's on it?
390cfm 500 cfm?
where did you find it? did you see any rebuild kits for it?
I know lot's of questions. but now that I have a starting point maybe I can get some stuff stockpiled for the turbo mock up for the dart later on.
THANKS!!!
