HOLLEY 3310 750 REBUILD HELP
Fuel and Air Systems
  1. B'cuda
    B'cuda FABO Gold Member FABO Gold Member
    176
    134
    Feb 13, 2018
    Newburg MD
    Local Time:
    7:54 AM
    First the problem: hesitates at speed when you let off the gas and then get back on it, feels like a lack of power when cruising but full throttle take off not a problem. Carb is a 3310 750 vac. secondaries, two metering blocks
    I'm going to go through the carb this weekend mainly to clean and see what jets etc ( cant remember ) are in there. I changed the squirter from a 31 to 35 and that helped some.
    The car is 69 barracuda, 340, 10.5 to 1 pistons 040 over, X heads, 1 5/8 headers, old D.C. 471 lift cam, LD340, D.C. electronic ign . 727 w 2800 stall, 355 gears. Combo was good for low to mid 13s at 105 mph on street tires. Would just like to cruise with a crisp throttle response.
    Any suggestions on jet, power valve, and vac. spring size, throttle cam, for a decent baseline would be appreciated. Thanks in advance
  2. DJC
    DJC Well-Known Member
    229
    46
    Sep 6, 2012
    Chilliwack, BC, Canada
    Local Time:
    4:54 AM
    Did it just start doing this? Anything change or happen? Is you accelerator pump working and adjusted properly?
  3. B'cuda
    176
    134
    Feb 13, 2018
    Newburg MD
    Local Time:
    7:54 AM
    About 2 yrs ago ethanol gas dried in the system, I replaced everything but the carb, that I took apart and cleaned, I replaced the pump daiphram and power valve.Cant remember what size, the original wasnt marked. I probably got something adjusted wrong. What's the adjustment procedure for the pump? Right now it's has slight pressure on the arm and the spring is almost bound at idle.
  4. DJC
    229
    46
    Sep 6, 2012
    Local Time:
    4:54 AM
    • Like Like x 1
    • Thanks! Thanks! x 1
    • sireland67
      sireland67 Well-Known Member
      7,566
      1537
      Oct 27, 2010
      WV
      Local Time:
      7:54 AM
      If you had gas dry up in it I would get a crock pot, just for garage use.
      Mix simple green and water, about 50/50.
      Tear the carb apart and boil it for a while, do not leave it in there for too long or it will strip the anodize off the carb.
      You will be surprised and the garbage that is left in the bottom of the crock pot.
      • Like Like x 2
      • DJC
        229
        46
        Sep 6, 2012
        Local Time:
        4:54 AM
        Also, power valves are based on vacuum levels. You need a vacuum guage to choose the right one for the application.
        • mderoy340
          mderoy340 Well-Known Member
          1,971
          667
          Aug 2, 2012
          Melbourne FL
          Local Time:
          7:54 AM
          72/78 jets
          PV 6.5 PVRC .063
          Orange cam #1 hole .035 nozzle adjusted for instant shot.
        • B'cuda
          176
          134
          Feb 13, 2018
          Newburg MD
          Local Time:
          7:54 AM
          Thanks for sharing mderoy, what is the PVRC?
        • mderoy340
          1,971
          667
          Aug 2, 2012
          Melbourne FL
          Local Time:
          7:54 AM
          The 2 small holes that fuel flows thru when the PV is open. They should be approx .059 - .063
        • B'cuda
          176
          134
          Feb 13, 2018
          Newburg MD
          Local Time:
          7:54 AM
          Thanks again, I assume if they are smaller, drilling them out is the fix ? Do you run the 3310?
        • mderoy340
          1,971
          667
          Aug 2, 2012
          Melbourne FL
          Local Time:
          7:54 AM
          Best to measure what you have for reference. Someone may have previously drilled larger. Also the purple spring has always work well for the secondaries. I've run a 3310 in the past but now run a Demon 750 dp. DP 60' better for racing.
          • B'cuda
            176
            134
            Feb 13, 2018
            Newburg MD
            Local Time:
            7:54 AM
            Turns out it was already pretty close, orange cam, PV6.5 PVRC 0.0625 70/76 JETS, changed now 72/76. Found two other problems on tear down, one dirt ( clogged passage in meter block) and the floats down travel was limited by the tip of the accerator pump's plug.
            Test drive: got my neck snapper back!
            Thanks for the help!
          • B'cuda
            176
            134
            Feb 13, 2018
            Newburg MD
            Local Time:
            7:54 AM
            I'm going to try th
          • DJC
            229
            46
            Sep 6, 2012
            Local Time:
            4:54 AM
            Glad you got it.
          • B'cuda
            176
            134
            Feb 13, 2018
            Newburg MD
            Local Time:
            7:54 AM
            I'm going to try th
            Thanks for the help DJC, the video was useful and I since found my Vacuum gauge and will fine tune everything!
            • Like Like x 1
