rklein383
- Joined
- Dec 2, 2005
- Messages
- 2,215
- Reaction score
- 1,815
If you advance the timing at idle and it picks up RPM, the engine wants the timing. Distributor will likely need to be altered to keep total timing at a reasonable level.
Main jets have zero to do with your idle if the engine is tuned properly.
Get the initial timing set properly FIRST! Then start tuning the carb idle settings.
Crackedback is right.... Main jets limit fuel delivery at WOT and have nothing to do with idle quality.
