Badart
Senior Member
Numbers on the air horn is 9022 0825 and is listed as a marine carb. There are improvements over regular double pumpers, like sealed shaft and vent tubes are turned down to avoid sloshing out (although one is broken off as you can see, but won't affect performance. It does need to be cleaned and a gasket set at the least, but the shafts are smooth and bushings look tight. Not sure what squirters or jets are in it. $120 plus the ride.
