Badart
Senior Member
I have another question about my 4160 600cfm. My problem is more annoying than anything. While cruising in 3rd gear and I roll into about half throttle my engine cuts up a little, like it's running lean. Idles perfect and when I put it to the floor it runs like a raped ape.
Background on the combo is 318 with only about 800 miles on it, flat top pistons 9:1, XE256 flat tappet cam, 1.6 roller rockers, magnum heads, accel dist, chrome box, headers, 3k stall convertor, 3.89 gear.
For jetting I am running 66 primaries and 72 on the secondaries (I installed a secondary metering plate because of it being lean on the top end). 6.5 power valve and I am pulling 12" of vacuum at idle. Timing is set at 16 initial, 34 total and with vacuum at 3k I am all in at 52 degrees of timing. Spark plugs look good after a hard run.
It almost seems like the secondaries can't decide if they want to open or not. Should I try a stiffer/lighter spring in the secondaries? Or do you think it is a dist spring issue? The dist advance seems to working just above 2k rpm. I am running champion plugs. After reading a recent thread I am wondering if it could be my plugs. Thanks for the help.
