Hi all,
I have a Holley 1850 600cfm vac secondary carb and I bought the secondary metering block conversion so I can change the jets in the rear. What jet size should I start with? is it 12 sizes larger than the fronts? I am running 68 fronts and I put 80 in the rear. It just feels like it is not getting enough fuel. I also did the quick change spring kit, and tried a med/light spring. Float levels are set. just feel like it's starving for fuel
Thanks, Paul
Thanks, Paul
