Hi, I have a 650 DP on my stock basically stock 5.9L magnum engine. I had it on my 360LA last summer and it was decent other then a slight bog from stand still. So I'm wondering if any one can help me with a quick question about how to delay the secondaries from opening so soon.
I'm going to rejet the carb, accelerator pump kit and the discharge nozzles a few sizes smaller then whats in it now. (Running rich btw)
Will the pump cams delay the secondaries so i can get the rpm up a bit higher to use the extra fuel and air?
