forcedfedmopar
So, not an A body but still a mopar. Ive been racing my pick up for the past year with the eddy on it and tuned it the best I could. Truck went a best of 9.74 at 76MPH in the 1/8th. It always had a terrible BOG off the light. 2.45 60FT best ever. Usually consistent 2.48-2.5.
Now everyone at the track told me to go get a holley and throw the eddy away. Being a novice at carbs I did what I was told. An opportunity came my way and I traded some work for a holley 670 street avenger with electric choke and vacuum secondary's.
I promptly put it on, set the float levels, mixture screws to highest engine vacuum, set idle and fast idle, and im off to the track. :blob:
My 60ft dropped to a 2.42. the BOG is less than before but still there slightly. My 330 times are slower and the 660 is now a 9.99 at 73MPH!
vehicle;83 D150 short box 2wd
engine; 77 400. single plane, headers, SMALL hemi grind cam
trans; 727 stock stall (12-1400)
rear; 8.75 3;55
So recap, truck goes slower with holley, I lost top end. WHERE DID IT GO AND HOW DO I FIND IT?
Thank you.
rear; 8.75 3;55
Thank you.
