Holley adjustment ..
orangecrush
How is step 3 performed below (tweaking kickdown) - where's the screw (vac secondary Avenger) The tuning DVD I got from Holley was blank !
1. pull kickdown off of the carb.
2. set the gas pedal to WOT.
3. looking down the carb, adjust the accelerator linkage until the throttle plates are straight up/down.
4. adjust the kickdown linkage so that it is fully engaged, while the carb is at WOT.
5. Place the kickdown linkage back on the carb
6. remove weight from gas pedal
