Retroboy
Howdy and help. I have what I was told is an 850 Holley methanol carb. Did Holley build such a thing? I can only find references to 750 and 950 for meths. It has no choke horn and on the primary metering body it has L 47812 stamped so a quick cross reference to the Holley number reference on their page tells me it's an 850. It has Annular boosters (the rears are loose which doesn't seem normal?), 50cc pumps 4 corner idle screws. It has P32 cast into the body and I know that smarter people than me know that means something but I suspect it's only going to tell me it's an 850. I had a look at the jets - primary are approximately .140" numbered 72 (re drilled?) and the rears are a hex shaped thingie that screws into the metering body with about .150" drilling. How do I know what size the needle and seats are they aren't numbered? but have 4 square openings about again about .150". I specifically told the guy I got it from it didn't want some bodgy home converted thing but I'm starting to think that's what I've got.
Can anyone tell me what the go is with this. It's been 30 plus years since I looked at a carburettor.
Cheers
Tony
Cheers
Tony
