[SOLD] Holley Avenger Carb and Nascar Fuel Pump
GMachineDartGT
Senior Member
Huntington, NY
Fresh off my pro touring small block Dart is a carburetor package. Avenger 770 jetted as noted in the picture. Works flawlessly, perfect choke zero issues. The mechanical pump is the nascar 6 valve no longer made by mopar performance. Comes with custom lines and regulator. Selling as a package with freight included to the lower 48. Parts located in zip code 11746. Paypal accepted too. $250
Two quick questions;
1) What basic engine combo are You running, c.i./cam/heads............
2) Is that regulator a "dead-head" type only with fuel gauge/NOS gas taps, or can it be run as a return type setup
Thx.............................
410 stroker, edelbrock heads, 230/243 hyd roller. Im sure the reg can be run either way.
