Holley Blue pump propeller offset?
doogievlg
Amelia, Ohio
I was given an old blue pump last year and figured this winter would be a good time to throw it on. I pulled the plate off to look at the blades and noticed the propeller is offset, is this normal?
Yes. It should be off-center so as it turns those 4 piece slide in and out.
Jake
Ever seen a pump out of a 200 or 700 GM trans?
Same design as this. (called a rotary vane pump)
