thanson_mopar
tell me the info on holleys, what does double pumper mean? whats the difference in the different models of holleys?
I don't think he'll EVER ask another question:toothy10:
Ya can't make a Carter a full mechanical secondary carb. The closest you can come to that would be (on an AVS) to remove all tension from the air valve spring or (on an AFB) break down the carb, remove the air valve assembly and remove weight from, or entirely remove the counterweight(s)
The web site for Holley is Holley.com. There is a lot of useful technical info there.
I worked at Holley in Detroit for 10 years during the late 70's. Man, I missed the good years by 10 plus years. I used to hear some perty good stories from some of the older engineers. I would eat lunch with Zora Duntov in the caferteria when he was doing intake manifold design there after he retired from GM. I would bug him about my '69 'vette...irat:
What is the advantage to running mechanical secondaries against vacum secondaries? would this be a good rout to go?(buy the 650 DP?)
The advantage would be secondarys NOW! when you want them.
For a performance engine/car, yes, it is the way to go.
Theres one little tiny catch to the DP though. You'll need to be able to use the extra cfm's when you want them and that could cause a problem if the set up is not ready for them.
You'll have to tune the carb just so. To much throttle opening to early will cause a bog and the race.
Things that favor the use of a DP are;
A lighter car
Steep gears
High stall
Manual trans cars DP's.
A slightly smaller CFM needed for the cars engine is the way to go for a street car of mild performance. (This will keep velocity up when all barrels are opened to early vs a larger carb that will kill velocity and performance.)
Of hand, I don't remember your engine size and specs, but a 650 will work well on most everything small block, OE, cid.
Your foot can control most problems, but then again, the foot gets you into most problems. He he he.
Low 13's should be esay enuff. Alot is also in the suspension and so on.......
also what is four corner idle?
ok, well i should look for a 750 DP then?
