Holley Double Pumper ID
smartken22
U.S. Navy Senior Chief
Lemoore, California
I am getting ready to rebuild my carb as part of my resto and want to make sure I order the correct rebuild kit. I believe that this is a 4150 series 650 double pumper...am I right? The only numbers I found were on the top of the carb. Let me know if you need more numbers. Thanks in advance.
That is Correct......
Just give then that number for you kit, and you'll be on your way !!!!
650dp
4777-*
The kit you have listed from jegs is what you need.
It's a 4150 Holley 650 double pumper in my book. It says the Holley kit is #3-489
