RockinRobin
Any of you that have used Holley carbs with adjustable needle and seat will have to replace the gaskets eventually. There are 2 different gaskets, one for the screw and one for the nut. When ordering them, I noticed that the one on the bottom under the nut is called the "top" gasket and the one on top of the nut between the nut and the screw is called the "bottom" gasket. Does anybody know why Holley calls the top one the bottom and vice versa??
