Holley Projection any good?
mean318
Schweinfurt, Germany
Hello, I just picked up a used holley pro jection 4 setup and I was wondering if I should use it? I have heard good things about them. What should I look for and would it be worth it. I have a ede avs carb on mine now I also have a thermoquad non- smog that I liked also. any help would be greatly appreiciated
You will get as many advantages of fuel injection as the drawbacks of carburetion will allow. Those drawbacks primarily being the retention of a "wet runner" intake. The projection system is a simple, robust throttle body system. Since you have one, why not give it a shot? If you're not gonna use it, I'll give you my address...
Seriously, I wouldn't expect a huge power increase over a well dialed carb setup, but starting, drivability and economy should be better. Make sure you use best practices with your install and it should be happy.
