[SOLD] Holley Street Avenger 670 VS
rednesss
Eugene, OR
Hi all, I have a Holley Street Avenger 670 VS for sale. It currently has 68 primary, 76 secondary jets. A 32 squirter, orange cam, and the black vacuum secondary spring. The Idle Feed Restrictor (IFR) has been drilled and tapped to accept 6-32 brass set screws and currently has a .031 restrictor in it, but I can include a set of .028 with it as well. It also has the blue, re-usable gaskets and nylon fuel bowl bolt gaskets. I can also maybe put different jets in it, or a different cam, or different VS spring if you request it, I have just about every size, just ask. I'm asking $175.00 plus shipping from Junction City OR 97448. Paypal only.
Thanks
How would I know? The IFR's don't have anything to do with the CFM flow of the carburetor. It is a 670 CFM carb, that is determined by the venturi sizes. The IFR's are often drilled to address a lean tip-in from idle. That is why I did it.
thats why i asked... was hoping maybe it would be flowing like a 750 or better, which is what i need. ..good looking, clean carb you have.
