Holley street avenger metering block
gliderider06
Delaware
Can anyone tell me the part number of the primary metering block on a Holley 670 street avenger carb? I have a carb that's missing one and want to replace it.
Thanks in advance
Without pulling the bowl off.. on the side of the metering block just above the air mixture screw mine has stamped into it 2 11761. These are the only numbers I see on the block. There could be other numbers behind the fuel bowl but I'm not sure.
Good luck and hopefully these are the numbers you need.
Kevin
Kevin
Perfect! Thank you. That is what I am looking for.
Thanks again, Paul
