1967formulaS
Hi guys,
I've got a new 850 vac sec holley and put it on my 440.
The 440 is pretty stock but has the 383 closed chamber early heads and victor 440 intake. Not sure what cam is in it but it's a little lumpy.
Anyway I have set timing at 12 deg btc and my advance is 36 deg. I have the msd6al and my dizzy is a mechanical advance.
So I hooked on my vaccum gauge as I am having overheating issues (I'll post this issue separately) and the best I can get at idle is 15Hg at idle and around the same setting my advance. Before hand I was only getting around 10/11Hg.
I take her for a test drive and I have lost a fair bit of powerwhen I stomp on it, before I used the vaccum gauge. I was running the car a bit rich before I started.
I've got 73 jets on the primary side and 82 on the rear. Should I go up in jet size to 78 on the front to keep the same vaccum but get more fuel in?
