JGC403
I'm so close to getting my Duster (360, 4-speed) on the road again. Everything is pretty much back together, just some little odds and ends that need to be finished up. The Carb being one of them. Its a 80457 that was just rebuilt. We had a chance to start the car today and to see if we could get it to idle correctly, before we ran out of day light. It didn't. So for next weekend I would like to have a step by step on how to get this setup right.
This was all with the car sitting in the driveway, did not take it for a ride.
Tried to set the electric choke, but it wouldn't do anything. Not sure if its just cause we don't know how to set it or if something is wrong with it. We were monkeying with it before the the engine was fully up to temp. And it did have power.
This is what was going on, with the engine up to temp. I just put in a Auto Meter Tach, the car wouldn't idle below about 1400 rpm on the tach. If the idle screw was backed out until the idle dropped down to 1000 rpm, it would stumble then die.
As it was idling around 1400 rpm, I noticed it would hunt for idle a small amount. It would increase idle slightly then slowly go down again. The needle on the tach would show this but you could also hear the change in engine speed. Not sure what would cause this.
Last there was no bog or hesitation step on the gas and the engine would rev up instantly.
That's all I can remember now with what I experienced so far. I have been looking at videos on youtube, to see where I should start. First thing I'm going to dump some new fuel in the tank. The stuff that is in there is about 4 months old. We set the fuel bowls when the carb was being rebuilt. That's the first thing I'm going to check next week. Then I'll turn the idle mixture screws in all the way then back out 1.5 turns according to Holley.
Any more input I would appreciate it.
