mopowers
Trying to tune the 750dp on my 340. The carb has 4-corner idle. Turning the secondary idle mixture screws all the way in will not kill the engine. The primary IM screws work as expected. I understand this to mean the butterflies are exposing too much of the transition slot to the point where the carb won't respond to changes in the idle circuit. The only thing is I've backed off the secondary throttle position screw to where it isn't even opening the sec throttle blades at all. Any ides on what else I can try?????? I started out with all transition slot "squared" and have fiddled with it since then.
I appreciate the helps guys. I'm still kinda learning as I go so take it easy on my dumbass.
