Holley "Visi-Flo" float bowl covers...
I have several of these; send me a PM. They can be installed on the Slant-6 1920, but you lose the inlet baffle that diverts the flow of fuel coming in thru the inlet needle/seat. The Visi-Flow carb used a different float and a differently-located inlet needle/seat. This may or may not be an issue; before you buy a glass bowl, you may want to remove the baffle from your existing potmetal bowl and drive around to see if you develop any new flooding problems, stalling out on corners, etc.
Also, while it's nifty to watch the carb in action, think carefully about the safety of a breakable glass vessel holding gasoline under the hood. I'm not necessarily saying it is unsafe, it's just something worth thinking about.
