Home brew torque strap
T-Evil
Member
Stanford Illinois
I busted a brand new motor mount, so I decided to try and make my own shumacher knock off torque limiting strap.
I used 379 peterbilt stack bushings, (you can get these on Amazon)
A 3/8-24 heim joint off of Amazon
Some water pipe, and 1/4 inch flat steel.
All in, $11
Very nice!
Or you could just use a late '80s truck biscuit with the built-in interlocks.
Under $10 at Rock auto or your local parts store.
^^^ Looks good, should do the job nicely! Lots of ways to get that done.
I use a poly lock on the drivers side of my lil 360LA and pinned the motor mounts on my 390FE for the same effect.... cut off the stud and grade 8 bolt all the way through with a nylocking nut.
Truck mounts are thicker, are they not ?
I use truck mounts when I need to raise the engine for clearance with some headers .
The truck V8 biscuits are only marginally thicker than stockers, depending on brand I have seen some almost identical in thickness. The Cummins diesel mounts are the ones that are substantially thicker- but they match up well to the early A mounts ('66 and earlier).
Diesel:
^^^^ A countersunk 3/8" bolt through the biscuit mount does the same thing but without those goofy looking tabs.
I like the homemade strap though. Nothing like making it yourself. Nice work!!
