matty wardle
mopar dedicated
i bought a extra lifter with my new cam and lifters as i want to make a checking lifter for piston to valve clearance ,....................my question is where the pushrod sits in the cup in the lifter it moves up and down 3/4 mm,do i weld it when its towards the bottom of the lifter or when its up against the retaining spring at the top of the lifter,is that 3 mm play what pumps up when the engines running????????????????
