homeade checking lifter
matty wardle
mopar dedicated
brisbane
i bought a extra lifter with my new cam and lifters as i want to make a checking lifter for piston to valve clearance ,....................my question is where the pushrod sits in the cup in the lifter it moves up and down 3/4 mm,do i weld it when its towards the bottom of the lifter or when its up against the retaining spring at the top of the lifter,is that 3 mm play what pumps up when the engines running????????????????
Do you have adjustable rockers? If not, you will need an adjustable pushrod to zero out the lash with your solid lifter when checking PTV clearance.
