Speedy Pedi
I'll be routing the vapor and raw fuel back to fuel tank vent port on fuel tank, per Mopar action article by Rick Edenberg and FOBO. I'll locate the article and post it. my fuel tank sending unit has a an extra vent port on it but others have just used a tee fitting to connect to if they had just one vent port on fuel tank. Use a 1/4" fuel return line from Fuel/Vapor separator back to Fuel tank vent connection.
REFERENCE:
www.moparaction.com
www.forbbodiesonly.com
PARTS:
REFERENCE:
Fuel Vapor Return Line
Tech Question Peter Johnson, Edina MN, 1963 Dodge 440, 440I just finished reading Project Bold Beeper, Installment#13 and you mention a few times under the picture captions about installingand benefiting from a fuel vapor return line. The benefi
fuel vapor separator on 440 6pak?
Vapor lock 6-pack question/solution
440 6-pack 71 Charger with the expected vapor lock issue. The solution is to install a fuel-vapor separator, which I purchased a few weeks ago, to replace the fuel filter. I was going to run a fuel line from the return tube of the vapor separator back to the tank, replace the sender unit in...
Fuel Vapor Separator
First time on the forum Restoring 68 Roadrunner w/68 383 roadrunner engine, A833 four speed. Two vents coming out of fuel tank. One goes up through the body and loops back down. Is the other one a return for a "fuel vapor separator"?
www.69roadrunner.net
PARTS:
PN 29511922 4-piece fuel vapor separator/filter set for 1968-70 Plymouth Belvedere - GTX - RoadRunner and Dodge Charger - Coronet - SuperBee with Hemi engine & Hi-Po 440 engine
www.moparmall.com
