carcrazyguy
The hood hinge on my 71 Dart is rubbing the inner fender area as you lift the hood and close it??? Yet the passengers side is clear by 2-3 inches?? I noticed that the passengers coil spring is loose to the touch, and the drivers side is tight? So would the passengers side loose be letting the hood lean to drivers side maybe??
