crazyswede
Active Member
I tried search but couldnt find what i was looking for. I got a problem with my hood "warping" when closed. All the way down to when the securityhinge goes in it is straight and perfectly aligned but as soon as i close it fully i guess it would be when it reaches down to the hoodspring i get the feeling that the spring is pressing the hood up on the driverside leaving a big gap between the hood and the grill! where on the passengerside its almost completely tight.
Ive seen several pictures of both valiants and dusters having this type of issue and wonder if anyone knows a fix for it. Its highly annoying.
Regards
Staffan
You can see it on these pics i found even though mine is slightly worse then those
Regards
Staffan
