hood pin location
moparwedden
trenton,ontario,canada
Well I Have A 72 Duster And Need To Find Where These Pins Are Located On The Hood And Rad Support. Does Anyone Have Pics And Measurements I Can Have. Even A Template Off Of One Would Be Great. Thanks Guys.
I was under the impression that the rad saddle has a dimple, fro the hole location.
If not I can take the measurement for you, let me know.
Giles
My support brace had a dimple:
Giles
Thanks Giles But Mine Does Not Have The Cut Out You Have. Did You Have To Put It In. As Far As The Dart, The Saddle Looks Different So I Don't Think That Will Work. I'll Check To See If There Is A Dimple Where Yours Is Located.
I'm back with pictures, and yes those cut outs in the saddle are factory.
Do you not have a slotted area, on the underside of hood, for where the hole needs to be, kinda like for the scoops, there should be a location for it.
From the front of hood 4 1/2", pic. #1.View attachment 74155
From side of hood, 3 1/8", Pic#2View attachment 74156
From inside fender, 3 1/4", pic#3 View attachment 74157
From saddle lip, 5/8", pic#4 View attachment 74158
Hope this helps.
No I Do Not Have The Cut Outs. This Rad Support Came Out Of A Donor Car From The Wreckers. Can't Remember What It Came Out Off. Well Out To Drill The Pins. I'll Be Posting Pics Of My New Hood.
