I have a new set of Hooker Competition Headers that I'm going to install on my 360 with "J" heads and fit it into a 67 Dart GT.
I bought a set of Stage 8 locking header bolts with the intent of replacing the studs.
I was looking at the outer most screws on the "J" head and with the studs removed I see the studs actually penetrate the water jackets. Can I replace those studs with bolts and if so what is the preferred method of sealing the bolts.
Also is there any benefit to removing the material between the flange of the headers in order to spread the outer most tubes to make it easier to bolt them up.
Lastly, the engine is out of the car at the moment and I was wondering is it recommended or possible to install the headers on the motor and drop it back in. I realize I have to drop the suspension that goes through the drivers side of the header tubes.
I stole a photo from another post to show the flange material I was wondering about removing.
Thanks for the help guys.
