Uh-huh. And just wait'll you see the numbers you can generate if you combine the special 2" spacer with those "fire injectors" ("Run YOUR Car Without Spark Plugs!") JC Witless used to sell until Big Oil and the auto industries forced them off the market for obvious reasons. Don't try it til you add a whole lotta gussetting and torque boxes, or you'll twist your car in two as soon as you kick the accelerator to bring your Carter BBS down from the fast idle!
