Tims 66 Cuda
Mopar mid life crisis
I have a 66 Barracuda and have installed a grant wheel. The problem is the horn blows when turning the wheel. I,ve replaced the wheel adapter kit once already, as it hits the turn signal cam bolt. The other issue is the horn contact roller is worn, sloppy and allowing the adapter to hit the roller bracket. any ideas appreciated as I know some have this set up with no issues.
Thanks, Tim
Thanks, Tim
