19dartsport76
Active Member
76 dart sport
can't quite get this one figured out, it has been molested...
what is the original horn actuator? i'm thinking something in the steering wheel, as there is no button anywhere else i can find.
i took the steering wheel pad off and there is a black wire going to what looks like a rotating plate on the back of steering wheel, and connects to a terminal on a barss plate behind steering wheel pad/cover.
what would activate the horn? is there a switch/button missing between this brass plate and steering wheel cover?
i also found a blue wire connected to the horn fuse terminal, has a female spade connector on the end which is hanging loose...this is meant to go to horn relay possibly? it had a yellow (12v memory) wire for CD player
this connects to a "double" terminal at the fuse. the other wire is pink and goes up through the dash and is hanging below the glovebox...this is where they had the horn connected....they had a 2-wire running to the horn, one on each terminal of horn....conencted to this pink wire near glove box and other to a black with white tracer near glove box.....no clue how it would be activated though....
