/6 Matt
30 Degrees Crooked
So we have a hot tub that we got several years ago for free from a family friend. The pump recently blew a seal and started leaking at the shaft between the wet end and the motor.
The motor was replaced several years ago by the previous owner and they used a 2 h.p. pump instead of a 1.5 h.p. like what the tub was supposed to have. So whenever we tried to use high, it would trip our 20 amp breaker that it's on.
So we figured we would be best to replace the whole thing with a 1.5 h.p. pump. Does anybody know if it's remotely possible to find the pump motor and wet end assembly for the neighborhood of $100? Or is this just a crack dream?
Or would it be better to buy the $65 wet end (our current one is obsolete and they no longer offer replacement parts of course) and just upgrade the wiring and the breaker? The wiring is easy to get to, it's tacked to the floor joists in the basement ceiling and goes through the basement wall to outside.
What do you all think? Wet end and wiring job? Deal with the $200-$500 pump motor package? Or is there a cheaper option I haven't found?
Not looking to spend much money on a free hot tub, and not in the position of purchase yet. Just price checking/shopping.
