LovetheA's
I'm attempting to rebuild my Carter afb on my 67 383 Cuba for the first time and have run into some hiccups. I took a picture of the accelerator pump that came out of the carb and the new one that came in the kit. How do I transfer over the needed parts to the new one and why is the pump return spring longer and looks thicker? Does the spring shorten over time from being compressed? What will a slightly thicker longer spring do if put in? I'm pretty sure that the rebuild kit was the one specified for the 67 383 manual trans Carter. Any advice appreciated. Thanks
Carl
Carl
