How do I remove this trim? 71 swinger
2kids
Washington State
Hi Guys,
I want to paint this interior trim - how do I remove this piece? I suppose I could leave it in to paint it if it's really hard to remove and reinstall, just seems like removing it might be the way to go.
Any suggestions?
It is captured buy the outer drip rail trim. Take that off first. Then there is some clips in side that trim that holds it on. You should be able to pull it off.
should be like 3 or 4 screws then u just pry it off there will be like 6 clips on the inside but lucky for you they leave marks were they belong on the trim so if they fall off or down in the trim u can still put them back into place were they belong and it snaps on pretty easy
