How do you remove the reverse gear in an A-833
smartken22
U.S. Navy Senior Chief
Lemoore, California
I am currently in work on rebuilding the tranny and I have everything apart except that I cant get reverse out. The service manual says to use a suitable drift, but there is no room to get a drift on the back of the reverse shaft to punch it out. Any tips? Thanks!
Ken
I use a long brass pin, come through the input shaft hole. It's a little tricky, but once you get it to move a little it will pull right out.
hi, a real service manual shows a special tool to remove reverse shaft from case. its a bolt spreader, for pushing it out. just food for thought.
I made this spreader tool for reverse gear. Used a head bolt and a coupler and welded on other nuts.
red
I am in the process also, I used a sliding C-clamp, the kind you get at Lowes etc. just put a socket over the reverse shaft (same size or smaller)
and it will slide right out.
millertoolman on ebag has factory remover for around 15 bux...but the large c clamp with a socket works well too...
I finally got around to working on the tranny this weekend. I have been wrapped up with the bodywork lately. I finally broke down and bought the service manuals and ended up making my own tool and everything popped right out! Thanks for all the inputs. Here are some pics.
